Yesterday I removed the door seal from my Bosch washing machine as it needed a serious clean, which an hour in a bleach solution did perfectly. Removing it was bad enough as I had to remove the top, control panel and front to get to the rear securing band. The actual seal came out easily though. However, this was not the case when refitting the seal. The securing bands were almost impossible to get back on as they were so tight. I was considering removing the front drum weights to get better access. It took two of us and a thin spanner as a lever to get the bands on. The bands are the wire type joined with a spring at the ends. Is there an easy way to get these bands on or is it always a struggle? Would new bands go on more easily?
