I'm having the same problem of clean water filling up in the machine between washes. You suggest that the problem is likely faulty valves. To a novice like me, can you please clarify if this means the the hot and cold valves in my kitchen into which the washing machine pipes are plugged into? Are these straightforward to replace if I turn the mains water supply off or do they require a plumber to do the job properly.
Thanks!
Thanks!
