I have a 2 year old kenmore washer. After the cycles there is residue (dirt, sand, soap) left against the tub under the clothes. Water has drained but left the particles, any ideas?
filter in the machine is not blocked
outlet hose not kinked
outlet hose not blocked
outlet hose not too far down within the standpipe
standpipe is 40mm and not 32mm
trap is not blocked
waste run after the trap is not blocked
outside gully or grating is not blocked
