Hi
New member, first time poster.
Moderately enthusiastic DIYer who knows just enough to be dangerous and not quite enough to be effective....
I think I have dropped a boob. Pulling away the kickboards in my kitchen I found that I had a serious leak. This was traced to the inlet pipe where it connected to the washing machine. I swapped out the rubber washer at the back of the machine but to no avail - it continued. I swapped out the hose and this fixed the leak. However a month later my washing machine now stinks.
The inlet is syphoned off the cold water pipe that goes to the sink. The T points straight down. The old pipe that I swapped out had a bulbous, sophisticated looking connector at the end that connected to the inlet. The new pipe I bought is a cheap, standard connector.
I suspect that the old pipe with the impressive looking connection prevented water pooling and going all whiffy. I have failed to find one searching the internet.
Please could someone
a.Confirm that my diagnosis is correct
b1. (If I am correct) tell me what I should be looking for
b2. (if I am wrong) educate me
Many thanks
Dan
Many thanks
Dan
