I have a space next to a downstairs cloakroom that I would like to use to install a washing machine in.
I already have the water supply sorted but need a place to drain the washing machine to. I have found a 90 deg pan connector with a 40mm boss on that should be a straightforward replacement for the current pan connector (which leaks at the moment anyway...).
From reading around I realise I need to install some sort of air valve so the suction from flushing the toilet does not empty any trap I might be using.
I am not good with these things so was wondering if someone could let me know what I need between the washing machine hose and the 40mm boss on the pan connector to make everything work correctly. I assume that this is ok to do?
Matt
Matt
