I have a new washer (indesit) and when it fills it draws cold water.
The hot and cold inlet pipes are both connected and the valves they connect to are fine (when i take the inlet hose off, water comes through the hot valve) and open.
When the washer fills it only fills with cold water, whatever cycle it's on. I have a combi boiler - when my old machine filled hot the boiler fired up and this doesn't happen with this machine.
It fills with cold water fine.
Are there any suggestions as to what might be the problem?
(this is an intgrated machine so moving it is difficult for me)
thanks.
thanks.
