Washing Machine not spinning or emptying
27 Nov 2006
Surrey
i have a Hoover six AM110 washing machine
fills and starts cycle fine
it doesn't spin or empty
i have checked the pump and thats good
any ideas appreciated
have the same problem - cleared the filter but no change.
any ideas?
just checked mine for blockages
i've had a hosepipe going to the drum. runs out of the pump drain. no problem
hosepipe into the drain pipe end . clears through to the drain pump
tested element . all good
the pcb appears to have no signs of burn out or does any where else
taken the thermostat out . a little scaled up but no drama. haven't checked it though
It might be the multi-function/program switch. The newer ones are computer controlled, but older machines use multi contacts with a timer mechanism. Over time the contacts arc out.New switch probably in excess of £70.
If it is the program switch, take a fools advice! Do not try and clean the contacts!!
i am intrigued by this comment storeman[/quote]
