- Joined
- 8 Feb 2018
- Messages
- 4
- Reaction score
- 0
- Country
Hi
I just moved into a new flat and have a small kitchen. The place did not come with a place for a dishwasher so I had a plumber put in a branch on the cold water feed going to the boiler (combi in the kitchen). The standpipe is under the sink about 4 metres of pipe away through 5 fitted cupboards, in order to get the drainage going I have to drill through this and add a long extension to the drain. Right, so as I went to measure up properly, i noticed that there was a 22mm pipe running from the boiler to the drain standpipe already, through all the cupboards presumably the overflow pipe from the boiler.
I looked around online and in Wickes and couldn't really figure it out. Is there an array of fittings I can use to connect the washing machine drain hose to this 22mm overflow, the inner diameter of the hose is 20mm. Can i just get a 22mm equal T and a bit of 22mm pipe and shove the hose on or will that not fit, the hose is a bit rubbery?
I have a spare standard washing machine hose nozzel connector which having measured, I believe is a 32mm female screw connector, but I could not find any end fittings or 22mm to 32mm reducers that have 32mm male screws.
Thanks for advice.
Thanks for advice.
