The house that I intend to buy has only a hot water supply plumbing for the washing machine. Is this not unusual? What type of washing machine should I look out for?
The current owner has just added in the washing machine plumbing as part of the kitchen extension and agreement with us. He confirmed to me that he is taking from the hot supply when I asked whether the cold supply is from the mains or the tank. He didn't give a convincing reason why he uses the hot supply instead of cold or both.
At the kitchen sink, there's also an existing dishwasher connection and a newly added tee-off to an external garden tap. Could you think of any reason for his hesitation? Any idea how much it will cost to add in a cold supply involving hacking thru the current floor tiles 15 feet away from the sink area.
Hmm, well, I can of three convincing reasons, viz:
1. Lack of knowledge; or
2. Human error; or
3. Laziness.
It doesn't really matter what the reason was - it just needs to be put right. The reason that it needs to be put is that no washing machine will work properly on all programmes with a hot-only fill. For example, if you put delicates in to wash at 40°C, and the incoming water is at 55°C, then you're going to have a problem.
Sounds like a good day's work to me, and the cost of that depends on how much is charged by the person you engage to do it. Personally, I don't give out my rate, or any prices or estimates, on this site, but you'll probably find that others will.
