I have a 5-6 year old Whirlpool AWG 384. During spin cycle bearing in drum makes noise a bit like Concorde taking off. Actually makes same noise when drive removed and spun manually. Replace bearing - simple? Don't know if it is simple or not. Also there has been odd black mark left on clothes and rust and grease marks spattered around drive side of drum.
Have not had the back off the drum yet but it seems to me that the drum is leaking into the bearing housing and just replacing the bearing will not suffice. I don't know enough about the way these things are put together to know if it is possible for the drum to leak in this way. Neither do I know how much the parts cost. Does anyone know if I need to replace drum? Can this be repaired without replacing the drum and is it cost effective - or should I chuck it and buy another?
Thanks in advance
Boxit
Thanks in advance
Boxit
