I'm new heres so first of all - Hello.
My problem is to do with the plumbing under my sink. The other day I found that my washing machine had been leaking and pulled it out to check. While I was doing this, the plastic connector of the cold water fill hose snapped so I disconnected the hose from both the washing machine and the inlet tap (under the sink) because my taps are not the standard 3/4" diameter but 1 1/4 (3cm).
I cannot find one of these in local plumber's merchants. Also, the inlet tap is completely tightened but water still leaks from it and I've had to put towels down to soak the water up (a bowl fills from the drips in under half a day)
If anyone can help me fix this issue it would be greatly appreciated
