I have a Hotpoint Ultima 6kg washing machine.
Model type WMA 76
I can hear the watering entering the machine followed by a few clicks etc.
The drum will not spin,then i can hear the water going down the drain.
I have opened the door and turned the drum by hand.
There seems to be some resistance so i assume the belt is on but i would need to pull the machine out & look to make sure.
Can you advise what may be the cause from the above or can you advise anything i need to do to assist you more.
Thanks.
Model type WMA 76
Thanks.
