I've got 1 hot and 1 cold inlet available and the washing machine needs 1 of each however I've recently bought a dishwasher and need to plumb it into the same cold water supply.
I thought this was a simple task of using one of them plastic y-splitters as I've read many reviews on people using them and saying how good they are.
So I got one from screfix and fitted it as tight as I could with just my hands and straight away it leaked from behind the nut so I used some pliers to tighten it a tiny bit, this seemed to stop the leak so I tried the dishwasher however once it started to draw the water out the water started spraying out. So I tightened it more and more with the pliers and it still wouldn't stop. Eventually I tightened it that much the plastic end broke off.
I tried thinking of other ways to do this and ended up getting another splitter and connecting it to the back of the dishwasher as tight as I could with hands and then a tiny bit more with pliers. So from the cold water outlet under the sink it goes into one side of the splitter attached to the dishwasher and then the other side of the splitter goes off to the washing machine - daisy chained together!
The problem is the splitter is still leaking, its much better, not spraying water out but its still dripping quite a lot. Does anyone have any suggestions as to what I'm doing wrong here? Should I just try tightening it a bit more with pliers? I know washing machine hoses should be hand tightened as over tightening makes them leak but I am very tempted to just to tighten it another few mm, would you advise this or is there a better option?
Many thanks for any advice,
Chris
Chris
