washing machine
19 Apr 2006
Essex
hi my servis m6115 1100rpm machine has stopped working,it was ok last saturday then it stopped mid cycle.You can select a programme the door switch will click and then nothing happens apart from the drum will fill as normal spin once then npthing .please help ...........thanks in advance :cry:
the module on your machine will have burnt out. is expensive part. probably a reason for board failure. i.e heater/motor
