Looking to replace my washing machine as the drum bearings or something are starting to go and, at 10+ years old, I just want to replace rather than fix.
WHAT THE HECK IS GOING ON WITH NEW WASHING MACHINES?!?
With my current machine I don't use the majority of progs. There's one that has a cycle time of approx. 60 mins which I can set the temp anywhere between 30 and 90 degrees. And there's another that has a cycle time of approx. 30 mins that again can be set at 30 - 90 degrees. So between these two progs my washing needs are met.
Now, you're met with an array of progs, most of which seem to have cycle times of 2 hours +!!! Some machines do have quicker cycle progs, however they're limited to lower temps and/or they suggest you can only put in partial loads.
And the manufacturers are crafty. When you look at most instruction booklets, specifically the program section (which you need a degree in English to decipher!), many of the cycle times just have an asterisk with 'see machine display.' No doubt this is cause most of the cycle times are ridiculously long.
All I want is a machine where I can put in a full load and set it for either 30 or 60 minutes at the temp I want. I don't want to be limited to 30 - 40 degrees e.g. if washing towels and bed linen, however neither do I want to put them on the available hotter cycles that run for a minimum of 2 hours, usually closer to 3 or more!
Happy New Year
Happy New Year
