Good evening!
I'd be very grateful of some advice please.
I am renovating a flat and need to move the waste pipe, running it from the kitchen, across the hall, through the bathroom, and out the brick wall to connect it to the waste/rainwater pipe which is 110mm black PVC pipe.
This will carry waste water from the dishwasher, washing machine, a shower (fed from a combi boiler) and the bathroom basin.
I suspect that this is quite a load on a single pipe, which has a run from end to end of about 4m. There is a good drop, however, and the pipe will be able to be run between the joists.
My initial thoughts were to run a 50mm pipe and connect the dishwasher and washing machine at one end, then tee the shower into the 50mm pipe close to its trap using a swept tee, and then add the wash hand basin near the other end of the pipe just before it leaves the building.
Does this make sense? Are there any potential problems? Do I need any anti-siphon valves in-line?
Thank you.
Thank you.
