I am installing a shower in an en-suite and I am wondering on the way to proceed with the waste in view of the possibility of back-flow. The shower is being installed next to the bathroom and I wish to run the waste pipe through the wall and join it up with the waste pipe from the bath, approx 1 metre from the bath u-bend.
At this point the plastic bath waste pipe is connected to a 40mm copper waste pipe which disappears under the flooring and runs approx another metre to a boxed-in internal stack pipe joining it below a corner branch to two wc's. Running the new shower waste pipe direct to the stack would be quite a task
All being well can I assume that all the bath water will run away to the stack pipe without backing off to the shower. If this could create a problem should I consider reducing the bath waste to 32mm for a short length before the tee where the shower waste joins it or put in a non-return valve into the shower waste if there is such a thing or should I be considering some other way.
I would greatly appreciate any guidance on this. Thank you
