Waste into boss pipe - can I use conversion bend?
15 Mar 2009
Newcastle upon Tyne
This isn't my first post whilst attempting to replace a bathroom!
I'm trying to use separate 40mm waste pipes for bath and shower cubicle plus 32mm for basin which were all previously joined into a single pipe - I have a very tight gap beside a joist to connect into a soil boss pipe which I cannot get a compression elbow into.
I've found '90 deg conversion elbows' which I assume are to convert to solvent pipe? Can I push the end of this elbow which has no fitting directly into the boss pipe adaptor and connect the comp or push-fit end to the waste run?
I think I should have just enough room to get this in if this is an acceptable join!
Thanks in advance
