Hi All,
My kitchen sink waste pipe keep blocking and I would like some advice on the best way to resolve the issue. The pipe run is about 1.5m behind the kitchen units. Whatever numpty installed it, didn't leave an adequate angle (1-2 degrees) for the water to run away and this seems to be causing waste to build up and get blocked.
I have tried several things with success to remove the blockage, but it keeps reoccurring:
Replacing the pipe isnt really an option until I redo the kitchen, and I am desperate for some advice on how to resolve this problem longer term.
If you have advice I would really appreciate it.
Jon
- Plumbers acid - not that effective with this block to be fair.
- Rotating Auger type blockage remover - worked ok, but blockage reoccurred
Jon
