- Joined
- 25 Jul 2005
- Messages
- 36
- Reaction score
- 0
- Country
I'm in the process of installing new water supply and waste for a washing machine. All done except that I've discovered I need to run a new pipe through the wall to connect to an existing waste pipe. Not a problem until you realise the wall is 60cm / 2ft thick and made of stone. There is an existing hole I could take advantage of but that would mean running a narrower pipe than I 've run from the washing machine to this hole. Currently I'm using 40mm. Is there any reason why I couldn't simply use the next size down (whatever that is) to run through this existing hole and make my life a whole lot easier than either a) enlarging the hole or b) drilling a new one?
Richard
Richard
