waste pipe larger than 40mm
22 Feb 2007
Mid Glamorgan
The problem i have got is connecting sink waste pipe which is 32 mm to the bath waste pipe which is bigger than 40mm.So what type of connecter can i use,as i was going to use a 40 mm t shape connecter with a 32 mm to 40 mm reducer .I dont want to replace bath waste pipe so is there any universal fittings for this metric bath waste pipe to connect to the standard 1 s in the shpos (32mm -40mm).
Thanx
Thanx
What size is the existing waste :?: A compression tee might do the trick :?:
Thanx for your reply to my question the bath waste pipe is slightly larger than the 40mm ones.
Different makes vary in size so see if theres any writing on the pipe or fittings.
what is the lagest pipe a universal compression joint will take.As the outer diameter of the pipe is nearly 5 and a half inches.And a standard 1 is just over 5 inches.
We fitted one last week that was for 250mm pipe, probably cost more then your bathroom though :LOL:
You was talking 40mm at the start of the thread, where does the 5.5 inches come in
Thanx
A sink waste is bigger than 32mm or do you mean basin waste.
Make of old pipe and the job is easy :rolleyes:
Thanks for all your help and advice everone,As i have now done the job which was easy.I used a universal compression t piece and a reducer and the was job done.Cheap and straight forward.
