U
User
Hiya, for some reason the waste pipe going from my bathroom to the outside soil pipe is 32mm instead of 40mm
The pipe from the bath is 40mm then is converted to 32mm
This seems totally wrong to me
Unfortunately it is almost impossible to change because a massive extension roof covers the outside pipe totally
I am moving the sink a few metres further away making it 4m away from where it is teed into the bath waste pipe
I will be using a an anti-vac trap on the basin due to the length
I know I should use 50mm usually but since there is 2m of 32mm pipe going to the soil pipe which I can't change should I just use 32mm all the way now
I am worried that if I use 4m of 50mm pipe then 32mm to the soil it may create problems
Please somebody help this is a predicament indeed
