Max run with a 40mm pipe from a single stack SVP is 3M.
Considering it's a Kitchen & the normal problems with blockages with grease etc(not that I'm suggesting you're a salad dodger)....I'd recommend 50mm.
HTH
its supposed be a max of 2.5/3metre run before uping the pipe size so i would go with the 2'' (50mm). it would be better for blockages etc, people put allsorts down the kitchen sink!
