Here's hoping the experts can help!
In fitting one of those fancy chrome bottle trap wastes to a new bathroom basin all went well until I tried to connect the metal pipe from the bottle trap to the 40mm plastic waste. The 40 - 32 reducer (compression-type) I expected to fit, doesn't. The metal pipe from the trap is 30mm not 32 mm, so it will not fit into the reducer ar all - far too sloppy on the outside diameter and the plastic shoulder/guide on the inside of the reducer is too big for the inside dia of the metal pipe to slide over it!
The trap, etc came as part of a basin set from Next some time ago, if that helps.
Is there such a thing as a 40 - 30 reducer & where can I get one?
