I am sorting a job out for a local company.
They complain that the urinals are blocking,
Only 2 urinals with a 32mm pipe work tee'd together between each other with a 'cross' tee, then straight through the wall to drain, all in 32mm pushfit waste on a 2.5m run.
I'm going to replace all pipework with 40 or 50mm ABS, What are the regs?
(i know a range of urinals should be done in 50mm but my head is saying 40mm will be fine).
one more thing - the urinals are on bottle traps - is this correct?
and one other one more thing - anti tamper TRV's and l\s valves - where to buy?
