I have to run SWA from the house through the back garden. This will be buried at 45cm and run through some plastic pipe for ease of replacement if necessary.
I also have to run some MDPE pipe from roughly the same place parallel to the SWA for an outside water tap within the garden. This could also be inserted inside its own plastic pipe if necessary.
I know that this work will be notifiable. What do the regulations state about SWA and water pipe being buried together? Is there a distance that they should be apart? Thanks
