Hello,
I have a 175 litre water butt which is filled primarily by a rain water diverter.
This works a treat, empty to full in three hours of rain last night. Whilst we live in a rather wet country I do at some stage in the summer hope that I will be using it more than the rain can fill it!
I would like to plumb in a pipe from the mains water feed to the tank and terminate it with a ball float valve. Something like this... http://www.screwfix.com/p/pegler-prestex-float-valve-part-2/27627
My question is that to make this work only when the tank is nearly empty, the float will have to be submerged under 500 - 600mm of water most of the time. Obviously this will mean the float will want to fly up out of the water. Will the force of the upward pressure cause the valve to fail over time?
Is there another way of achieving the same thing?
Thanks in advance.
Thanks in advance.
