water coming from underground to my tank..need help????
15 Sep 2008
hey guys my problem is somewhat confusing...................so listen my factory is at ground level but for furnace we made a 10 fit tank below ground level (10 fit is its deep ness) but the tank does not have any construction made at its sides.......that is it is only made by workers . the tank dimensions are(15 x 12 x 10) fit
so the problem is when in rainy season the water comes from sides of tank & also from base ............ I want to stop the water coming from all sides ........... tell me the solution plzzzzzzzzz it s urgent need help
Hi. With out more information with regard to construction of base and walls it it difficult to answer. What ever method you use to cure your problem be aware that if the water table rises it is possible that the cistern will pop out the ground (like a boat when the tide comes in.) Good Luck
Build it properly, not just a hole in the ground.
Use proper construction methods & workers that know what they are doing.
Make a floor, waterproof it.
Make the sides, waterproof them.
Make a top, waterproof it.
Ensure you have flood prevention thats waterproof.
