I posted this before, seems like it might be relevant here.
Giving the garden a good watering was taking 400-500 litres of water per night at a cost of nearly a pound a go. This was pretty expensive last summer.
I've bought 3 large (200 litre) water butts, a large submersible pump and some hoses and with a bit of rerouting of our waste water piping I'm collecting nearly that amount of water a day from showers and baths and although I still have one water butt to install the system is in and working a treat!!
The pump states it can shift 130 litres a minute, and whilst this is clearly reduced down 15 metres of 15mm hose, there is still enough flow to run two hoses (sairee/emily and I can water the garden together now) at a similar rate that I used to get from the outside tap.
Really pleased with the system, total cost about £100 I'd say - the pump even has a float switch, so switches off when the butts are empty.
See attached pictures below:
This shows the submersible pump and my two-way adaptor that I made from a hoselock 3way splitter and some epoxy.
[url]http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0976.jpg [/url]
Two of the three water butts at the side of the house, the large white pipe carries both bath, shower, basin and all rain water from the roof.
http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0974.jpg
The pump in place in one of the butts, you can see the float switch
http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0980.jpg
The two hoses, I bought a 30m hoselock professional hose (really good hose actually) and cut it in half giving two 15m hoses
http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0977.jpg
This shows the 15mm copper links between the bottom of the tanks, this keeps the levels in them all the same.
http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0978.jpg
Another one of the adaptor
http://s81.photobucket.com/albums/j205/toastyboy1976/?action=view¤t=DSCN0979.jpg
All in all a sucessful project, needs a bit of finishing off, I'm fitting an outside socket, cut the lids to shape, fit the final water butt in place, but it's working really well, I gave the grass the full 400 litres yesterday and it's looking really green and lush, and best of all it didn't cost be a penny - well aside from the 100 or so quid, but I love gadgets.
Here's the pump
http://www.tooled-up.com/Product.as...-Lift-And-130l-M-Max-Flow-+-Float-Switch-240v
Hope it is of some help.
-Dan
