- Joined
- 31 Dec 2003
- Messages
- 173
- Reaction score
- 1
- Country
My daughter's flat has a combination cylinder and in the top section there is the remains, in several bits, of what looks to be a heavily calcium encrusted rod or pipe bent into a hoop - it looks as if it was about 12" - 15" in diameter orginally.
I've read somewhere about sacrificial anodes but from their description they seem to be straight rods and this 'thing' doesn't seem to have been that shape. Also I believe that the anode sticks down into the bottom section of the cylinder? There is a 1" length of what seems to be a rod sticking up from the bottom of the top cylinder section - could this be the anode? It doesn't look to be in a condition that would enable it to be removed.
Does anyone know what the decayed hoop may have been and what purpose it served? Could it have been connected to the small section of pipe sticking up from the centre of the cylinder?
How important is it that I replace the anode - assuming that I can remove it and source a replacement? I'm replacing the immersion heater and am concerned the new unit may corrode very rapidly without the anode.
Finally, adverts for replacement cylinders suggest they no longer need anodes so I assume they are of different construction or did the presence of an anode actually serve no useful purpose?
