water everywhere
30 Nov 2004
I have a glow worm compact e100 combi boiler.(lucky me)
I had been having problems with hot water, somebody told me to check the thermistor, i turned electric supply of but forgot to isolate water. When i removed the thermistor water went everywhere. I mopped most of it up and tried to dry electrics with hairdryer. When i turned it back on "power on" light appears "winter setting light" appears "central heating demand" light appears but BURNER IGNITED light does not, no sign of boiler light. When i turn everything on it clicks when i turn thermostat on no central heating it just clicks. any ideas and yes i am a plonker.
Thanks for replying. Could you explain what you mean by take the plugs of the pcb? I do not want to make things worse, lacking a bit of confidence after my last incident. Thanks
the water collects inside the plugs you may have dried the board and still have a short inside the plug/s :cry:
you may well have shot the board as well :cry: :cry:
