Hi everyone, ok I know that I am probably going to get cussed for this. But wanted advice/opinion.
I just fitted a 9.5 kw electric shower. For ease I took the supply feeding the shower from the same pipe feeding the bathroom taps.
When I turn the shower on cold everything is fine, apart from cold water. As I turn up the heat the flow slows down.
Is it because it is a crap shower? Or because I have the feed from 15 mm pipes that feed the taps. Should I have checked the water pressure first?
If I should have can I test it just before it goes into the shower? Is there a push fit gauge I can use?
Sorry I know a lot of stupid questions!!
But thanks in advance.
Kam
Kam
