B
B.O.B DOLE
this is a combi can someone tell me, when water flows from the mains to the boiler it goes through a flow restrictor, then the water flow switch tells the pcb the correct demand then primary water is diverted to plate heat xchanger
my question is if i turn on the hot tap, the water flows throu restrictor but does it then go to the 3 way valve and if so is there a switch which senses that the hot tap is on or does it go to where the flow switches are which send the signal to the pcb are is all of this bull..........
