I've just had a new boiler installed to replace a worn out unit. During the installation the engineer added TRVs to most of my radiators.
A new pump was installed directly above the new boiler connected to its outlet. This pump is connected the right way round but the water seems to flow backwards through the system as though the pipes are crossed from that point on.
The upper pipe to the hot water tank is always hotter than the lower pipe, which leads directly to the motorised valve. The radiators seem to heat up from back to front. It seems the motorised valve is now at the end of the pipework rather than the beginning.
So hot water is flowing through the pipework, does it matter that it's going the wrong way?
I've yet to agree that the system has been installed correctly and pay the balance owed. Should I?
