Hi
We have a water downpipe from the gutter which empties into a drain. I want to make sure that its not leaking underground (and under the house!).
I have an inspection hatch on the other side of the house where there are more drains and where I think this downpipe water is emptying into.
Ive stuck a hose in the downpipe drain to test this. The odd thing is that it takes a good 5 minutes of water from the hose before I start seeing the water coming out into the drain on the other side of the house. Why would that be!? The house is on quite a steep slope so the drop on the pipe should mean the water enters the other drain almost immediately after I turn the hose on.
Also, the water coming out into the drain doesnt seem as fast moving as the water coming out of the hose, which is concerning as that might mean the pipe's cracked underground(?)
I hope Im explaining myself well enough.
