I had a new heating system installed in my flat to replace an archaic gas fired warm air heating system and a gas fired water boiler in my kitchen.
I had it installed in my loft on the gable end with new pipe work and rads. I also had a pressure accumulator fitted due to the mains pressure being a little weak.
The problem I have is that when I put the hot tap on full it takes 30 to 40 seconds for it to start flowing hot water.
Could this be due to the pressure accumulator? based on the pressure it seems the hot tap has a lot more pressure than the cold tap. My logic tells me that pressure accumulator should be assisting the pressure of the cold water as adding cold water to a hot water feed seems illogical. Maybe that is why its takes so long to get to temperature?
Any advice welcome.
thanks,
Degs
Any advice welcome.
thanks,
Degs
