So new cistern connected to cold water mains via plastic push fit and old copper pipe. New cistern valve seems to snap off rather than the slow close of ball valves. The creates a hammer more in the old pipe work which was "professionally" done when the house was built. That is supported and clipped with nails. That's a given unless I lift all the floors and fix it properly with plastic clips. And that would just cure the bang not stop the shockwave. The new plastic pipe is clipped.
One option is to add an arrestor (cheapest at toolstation it seems) but I wonder if fitting a piece of flexible hose would also do the trick. Gut feel is that the rubber hose would absorb the shock, at least some it. I wonder if anyone has tried this and has it worked? A rubber hose is only a few quid so about 1/10 the price of an arrestor.
