We had a new washing machine which is fantastic and quiet but has a very fast solenoid, so it creates a bang in the pipes as it closes. When it starts a cycle it seems to do lots of small fills, so we get a repeated banging. For the first few minutes then less frequent ones for the rest.
Now the old one didn't make any noise from the pipes but during the replacement of the washing machine we were having an extension built and to try and address another issue I replaced an isolation valve with a full bore one. Other than that the pipework to the utility room stayed the same.
After a little reading I found that this is an issue with newer washing machines and the fix is to install a water arrestor. So I promptly purchased one and fitted it between the hose and the isolation valve that it connects to (not full bore from the look of it).
However after fitting it doesn't seem to have done anything at all! I don't need to do anything else with it do I?
The only other thing I can think to do is to partially close the isolation valve at the washing machine. Would this help? Could it cause any issues? Any other thoughts?
