We have just done a large amount of plumbing ourselves in our renovated bungalow.
It's all been done to a good standard in terms of soldering etc and it's all in copper.
We have use 15mm pipes for the entire cold water system as that's what it was originally before being wripped out and redone AND because it's a 15mm pipe connected to the mains pipe that is concreted into the ground, with a 15mm stop cock etc, so i didn't see the point in using 22mm.
We have average water pressure, doesn't seem too high or too low, but i will get it tested properly soon.
However, we are getting water hammer mainly caused by the basin and sink taps being turned on or off.
I have instaled mini water hammer arrestors near the toilet and the washing mashines, which stopped them caused water hammer, but i installed one near the basin and it made no difference, maybe even made it worse!,
Also, all the appliances are being supplied at mains water pressure, with no cold water tank or anything.
Would a 25L expansion vessel help to stop water hammer?
And do you think my pipes are undersized?
If worse comes to it, i am willing to redo all the mains runs of pipe in 22mm, right up to just before the Kitchen and Bathroom, but they would still be fed from a 15mm pipe coming out the ground, so i don't see the point really.
