Water hammer problem
11 Jan 2009
London
I suddenly developed a severe water hammer problem 2 months ago. When any tap hot or cold is turned off or when the washing machine valves shut produces violent hammer in the pipes. There are 2 flats affected in a terraced house conversion sharing mains supply.
A plumber replaced a plate in one stopcock in one flat which fixed the problem for 2 days only. He returned and reduced the mains water pressure which fixed the problem for 2 days also.
What is the root cause of water hammer - does anyone know? I understand that the causes can be loose pipes or stopcock plates -- I don't want to pull both flats apart looking for loose pipes if that can be helped. Is there a simple way to go about looking for the root problem?
If it is the mains stopcock in the street how can this be solved?
Any suggestions gratefully received because I've already paid over £200 for a plumber to poke around and not fix the problem.
J.
