G'day folks,
I recently upped the speed on my Grundfoss 15-60 to setting 3 and the CH works like a dream now, even with it being a little noisier when the pump is running.
But now the problem is: If the CH is running and the 2 port valve to the DHW cylinder closes (when the cylinder stat is satisfied), the pump continues to run whilst the motorised valve feeding the cylinder closes, leading to a nasty thump sound, because of the pressure from the pump on the valve. Didn't do this with the pump on 2. If the CH is off then the pump switches off before the valve finishes closing and there is no thump, but often the CH is required whilst the DHW is heating.
Any clever solutions?
