Hi all,
My name is matthew and I'm a self employed window cleaner and I joined this forum to try and find out information from plumbers/engineers.
I will explain what I do and need.
I use wfp to clean windows (water fed poles)
I have a 650L tank of purified water in my van with a 100psi shurflo pump which pumps through 100m of hose and then up my pole to clean windows.
Thats a cold system I run but there are hot water systems available but they can cost up to 10grand!!!!!
So I would like to turn my setup into a hot water system.
My only power source in the van is 12 v.
Where can I get a 12v/gas water heater to fit into my system.
I would like some kind of boiler that heats the water instantaneous as it passes through.
I cant afford the time to wait for it to heat up a 15L tank. A average house would use 20L min to clean it.
Any help would be appreciated
Matthew
Clear Vision
Matthew
Clear Vision
