Water in ground floor pipework.?
17 Mar 2011
Hi guys
I drained down my open-vented heating system over a year ago and removed some rads, the system is not being used.
I have the feed pipe from the feed and expansion tank fully closed .I checked a few times at one of the rad valves downstairs where the radiator has been removed and there's about 10 litres of water draining out each time ,this is about 6 months after checking previously.
The oil boiler is slightly above the level of the ground floor pipework and I have drained it at the drain outlet on boiler.
Where would this water be getting into the heating system?
Thanks for any advice
Do you have a hot water cylinder with a coil inside ? Could be perforated. And make sure no water ,not a drop ,is getting into the f&e tank.
Hi thanks for your reply
I had thought about the coil leaking into the system
There's nowhere else it can get in apart from the tank and the coil is there?
Not really. Can you post pics of pipework around cylinder ? You may have isolation valves that can isolate feed and return to coil .
There's a valve on the bottom end of the coil which I have now turned off
