Hotpoint Aquarius washing machine.
Never did find the answer so just asking again.
Not always but now & then.
Cycle ends & I get washing out of machine. Everything is fine but sometimes I grab the washing for it to be dripping wet.
After removing the washing I normally would be looking at the drum with all the holes but I sometimes see water.
I’ve not moved the machine or pipe which allows water to drain so why even say 1 in 10 washers is there water in the drum.
I’m at the stage where now the cycle is finished I turn the dial to drain which helps but still some of the washing is soaked.
I can understand if I move the machine then yes I might of done something but nothing is different but water in the drum now and then after it’s complete.
Let’s say maybe a faulty inlet valve but then I don’t here anybwater entering the machine.
