Hi hope somebody can help my whirlpool washer worked perfectly until builders moved it from the kitchen into a new utility room it seems to make a bit of whine noise as though it is struggling to spin then spins at proper speed, a few inches of water is still in the base of the drum after spin cycle i also notice that water is continuing to run into the soap dispenser drawer even when the machine is turned off even at the mains the only way to stop the water is to turn off the water supply at the back any help or suggestions gratefully appreciated many thanks
