Hi All
My extension is progressing well but one big problem I have is water keeps seeping in through foundations into the new build area. Water seeps in when it rains especially heavy.
My area suffers from water table. It is an annoying problem. I have done a number of things to eradicate the seepage. Concrete filled base areas around foundation walls. Rendered drive side wall where water was seeping through foundation blocks. The water has slowed but not stopped it. My lawn slopes down to my extension that doesn't help. I have put in a temporary gully between the my new wall and the lawn it works but not 100%.
I have been told by two builders that the seepage will eventually stop but I not am sure and I find hard to believe them. I have 30-45mm depth of water inside my extension. Surely this is a perfect recipe for dampness and wet rot. So all of you please help me find the solution. What is the solution to this problem. I wish to thank you all in advance for your input.
