Hope someone can help with some advice on this. In the thaw yesterday we had both the cold and hot water pipes to the kitchen burst - a Boxing day treat! Unfortunately the the break under the kitchen was in the only part of the house which cant be accessed through crawlspace underneath and has been tiled from above so all that I could do was cut the pipe at the closest point I could get to and blank the pipes. I wont be able to get into the area concerned to repair or run new pipes but I think that I can run new pipes from a different route.
My question is to do with the water that escaped under the house. Because I cant see into that area I dont know how much water was there or if it has drained away. The house is a 1905 construction and I can walk or stoop under most of it except for the area where the kitchen is, which I think was an extension or perhaps conversion from an old coal store or such like. I know very little about house construction and I am wondering is this water likely to cause any damage or will it just drain away into the soil or is it something I should be concerned about?
