I am in the process of getting my water main renewed into the property.
The waterboard are going to renew with a 35mm pipe from the main up to my external stopcock.. Then my plumber is going to use a 25mm pipe from the external stopcock to the internal one.
I was under the impression that the 25mm was the internal bore but it is the external diameter so the internal bore is about 18mm.
I asked my plumber if it would not be better to use 32mm (25mm internal) & he told me that would be overkill. The threads i have seen on here suggest a 25mm internal bore is the way to go.
Property is a 3 bed 1 bath at the moment but will end up as a 4 bed 1 shower room 2 bathroom in the future.
Any comments appreciated as work begins next week.
Regards,
Sokari
Regards,
Sokari
