Hi all
I have a leak, well my meters going round.
I turned the stopcock off in the kitchen where cold water comes in via a ratty old bit of 15mm copper, meter still going round.
This morning I dug up outside the front of the house and found the cold water mains [15mm copper], I cut this and capped the end to eliminate copper entering the house. Meter still going round.
So now suspect leak from somewhere between water meter housing and front of house.
I dug round the water meter housing both sides but not wet, I suspected this as we've driven over it a few times and may have disturbed something. It looks dry round this.
Both sides of the water meter housing exit with a elbow that doesn't head towards the house? both exit point elbows head the same direction meaning they will have to cross somewhere. I have dug both sides of WMH albeit different times and both's sides dry sort of, rain runs off the road down onto this area so always a puddle over WMH cover.
Questions:
In the pic is the elbow shown likely to be off the road supply? I suspect it is but never done underground work before.
Also this elbow looks to be cocked up in the air which could be from driving over cover and forcing WMH down as only set in the mud/clay, should this exit off WMH square? at 90 degrees?
I intend digging along this pipe to locate where it reduces to 15mm copper. maybe it's leaking there so will eliminate copper altogether.
Kind regards
Brian
Questions:
Kind regards
Brian
