Hi Chaps,
Our water comes in from the main in what seems to be a 22mm black plastic pipe that sprouts up through the concrete floor slab.
From this it then goes into a stopcock where it gets reduced to 15mm, goes through the water meter and then back up to 22mm.
My question is this, does the 15mm restrict the flow of the 22mm around the house to the same as if it was all plumbed in 15mm?
this may sound like a simple question but then I thought is the flow more to do with the pressure as opposed to the pipe diameter?
Then I went cross eyed.
All advice is welcome - the reason I ask is because I want to replumb some of the house, will be using 22mm but want to know if it is necessary to get the meter changed, or to just do the lot in 15mm.
thanks in advance
thanks in advance
